38-60 Gonna be a lot of Trouble
Post a pic or two of the top and bottom of the transformer. Most have a couple of screws in the top that secure the coil and the can has a couple of spring fasteners that you squeeze with a pair of needle nose pliers the pop the can off.
38-60 Gonna be a lot of Trouble - by PAradiogeek - 03-18-2017, 01:24 PM
RE: 38-60 Gonna be a lot of Trouble - by Radioroslyn - 03-19-2017, 12:24 PM
RE: 38-60 Gonna be a lot of Trouble - by morzh - 10-01-2017, 10:09 PM
RE: 38-60 Gonna be a lot of Trouble - by morzh - 10-17-2017, 10:48 PM
The speaker table error?
Philco 70 antenna lead
