GE F53
Maybe not if you look over the diagram you'll note that the tuning cap has a coil in parallel with it so what your ohm meter is see is the inductor and not so much the cap. Now it you disconnect the wires from the cap and measure a low resistance then you've got a problem.
GE F53 - by vecher - 03-14-2017, 08:12 PM
RE: GE F53 - by morzh - 03-14-2017, 09:47 PM
RE: GE F53 - by Arran - 03-14-2017, 10:29 PM
RE: GE F53 - by morzh - 03-14-2017, 10:32 PM
RE: GE F53 - by vecher - 03-15-2017, 12:01 AM
RE: GE F53 - by OldRestorer - 03-15-2017, 08:02 AM
RE: GE F53 - by Mondial - 03-15-2017, 11:41 AM
RE: GE F53 - by vecher - 03-15-2017, 04:05 PM
RE: GE F53 - by vecher - 03-15-2017, 04:37 PM
RE: GE F53 - by Mondial - 03-15-2017, 04:41 PM
RE: GE F53 - by Mondial - 03-15-2017, 05:01 PM
RE: GE F53 - by vecher - 03-15-2017, 08:51 PM
RE: GE F53 - by Arran - 03-17-2017, 11:40 PM
RE: GE F53 - by vecher - 03-20-2017, 12:26 PM
RE: GE F53 - by Radioroslyn - 03-20-2017, 02:46 PM
RE: GE F53 - by vecher - 03-20-2017, 03:45 PM
RE: GE F53 - by Radioroslyn - 03-20-2017, 04:47 PM
RE: GE F53 - by vecher - 03-20-2017, 07:29 PM
RE: GE F53 - by vecher - 03-20-2017, 09:57 PM
RE: GE F53 - by Arran - 03-21-2017, 11:40 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
