GE F53
Terry, Osc is working. Checked it with a portable AM receiver. At 600 KC on dial I RX Osc at 1065KC.. and so on up the band. I will check the Grounds. I did notice that the volume has to be almost all the way up to hear anything.. And the 465KHZ signal from generator has to be pretty high to hear it. About 0 DBM.. So looks like not much IF gain.. Do you need a schematic ?
Thanks
Skip...
GE F53 - by vecher - 03-14-2017, 08:12 PM
RE: GE F53 - by morzh - 03-14-2017, 09:47 PM
RE: GE F53 - by Arran - 03-14-2017, 10:29 PM
RE: GE F53 - by morzh - 03-14-2017, 10:32 PM
RE: GE F53 - by vecher - 03-15-2017, 12:01 AM
RE: GE F53 - by OldRestorer - 03-15-2017, 08:02 AM
RE: GE F53 - by Mondial - 03-15-2017, 11:41 AM
RE: GE F53 - by vecher - 03-15-2017, 04:05 PM
RE: GE F53 - by vecher - 03-15-2017, 04:37 PM
RE: GE F53 - by Mondial - 03-15-2017, 04:41 PM
RE: GE F53 - by Mondial - 03-15-2017, 05:01 PM
RE: GE F53 - by vecher - 03-15-2017, 08:51 PM
RE: GE F53 - by Arran - 03-17-2017, 11:40 PM
RE: GE F53 - by vecher - 03-20-2017, 12:26 PM
RE: GE F53 - by Radioroslyn - 03-20-2017, 02:46 PM
RE: GE F53 - by vecher - 03-20-2017, 03:45 PM
RE: GE F53 - by Radioroslyn - 03-20-2017, 04:47 PM
RE: GE F53 - by vecher - 03-20-2017, 07:29 PM
RE: GE F53 - by vecher - 03-20-2017, 09:57 PM
RE: GE F53 - by Arran - 03-21-2017, 11:40 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
