  • 2 Vote(s) - 3 Average
What 16B Chassis Do I Have Here?
Hello Nathan,
My tuning requires the use of 2 knobs, one for the outer shaft and one for the inner brass sleeve/shaft.  I believe yours is a single shaft that utilizes a single knob attached with a set screw.  Yours is tuned by either leaving the knob in its natural resting position and turning or pulling it out and then turning for a different "speed".
Craig R
What 16B Chassis Do I Have Here? - by VntgRads - 03-20-2017, 03:25 PM
RE: What 16B Chassis Do I Have Here? - by VntgRads - 03-21-2017, 12:27 AM
RE: What 16B Chassis Do I Have Here? - by AI2V - 05-14-2017, 12:01 PM
New member
Philco 630csx power cord
New member
There are currently 4033 online users. [Complete List]
» 1 Member(s) | 4032 Guest(s)
