Re-Stuffing Canned Electrolytics - Part 64000
Continued!
After drilling holes around the circumference it was still stuck so I started using a larger bit and worked my way out from the center to the edges.  Eventually I got it to where I could pull out fairly decent sized chunks using some needle nose pliers and finally had it cleaned out to within about 3/4" of the bottom (or top if you will)
At this point it seemed like I was getting into some of the black tar-like substance similar to what was in the smaller cap.  So I resorted to heat.  Using a heat gun I warmed it up until it was obvious that the black substance was softening than started digging with a small screwdriver.  Finally the remains popped out
Now both cans had that black substance in the bottom so I filled them with lacquer thinner and let them sit a few minutes.  Using a screwdriver I swabbed a paper towel around inside them and after two or three repetitions they were both clean.
This is as far as I've gotten.  As soon as I find a Dremel attachment with a fairly sharp point I'll cut the get them re-stuffed!
Rich
RE: Re-Stuffing Canned Electrolytics - Part 64000 - by criageek - 03-22-2017, 09:41 PM
Ooh, very nice!jrblasde — 12:19 PM
I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye. It has 13 tu...Dan Walker — 12:07 PM
Hi guys! I’m a new member here but have been using your resources for quite some time. Hopefully I can get some help wit...Radios1340 — 11:52 AM
There are currently 7936 online users. [Complete List]
» 2 Member(s) | 7934 Guest(s)
