42-321 Alignment problem.
It was obvious that the oscillator was not working. I could only get the strongest local station all over the band. I also used the parts radio to check all of my wiring, clipping one wire at a time out of teh parts radio after checking it with my re-wired chassis. I found no mistakes. I also re-tested the tubes.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
42-321 Alignment problem. - by Guest - 12-17-2009, 08:53 PM
Re: 42-321 Alignment problem. - by Guest - 12-17-2009, 09:41 PM
Re: 42-321 Alignment problem. - by FStephenMasek - 12-21-2009, 02:04 AM
Re: 42-321 Alignment problem. - by exray - 12-21-2009, 07:15 AM
Re: 42-321 Alignment problem. - by FStephenMasek - 12-31-2009, 02:07 AM
Re: 42-321 Alignment problem. - by 7estatdef - 12-31-2009, 07:36 AM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4380 online users. [Complete List]
» 1 Member(s) | 4379 Guest(s)
