Correct toner laquer for Philco 90a
Hi Guys,
What color toner should be used for the front columns and base moulding on a 90a cathedral?
Thanks in advance for your authoritative suggestions!
Correct toner laquer for Philco 90a - by mcusi - 03-24-2017, 09:17 PM
Philco 91 Tuning Condenser
There are currently 10248 online users. [Complete List]
» 2 Member(s) | 10246 Guest(s)
