Correct toner laquer for Philco 90a
Hi - I don't know the answer myself, but if you haven't already seen this, here is a very extensive Philco 90 refinishing walk-through:
http://antiqueradios.com/forums/viewtopi...7&t=220363
And another recent restoration:
http://philcoradio.com/phorum/showthread.php?tid=14782
Correct toner laquer for Philco 90a - by mcusi - 03-24-2017, 09:17 PM
RE: Correct toner laquer for Philco 90a - by Nathan Slingerland - 03-24-2017, 11:59 PM
Eico 232 VTVM Schematic
There are currently 9639 online users. [Complete List]
» 1 Member(s) | 9638 Guest(s)
