GE H-632U Ballast Resistor Hytron K42B
Same as mine but remove the diode and 33 ohm resistor. In it's place add a 8.5 uf non polarized cap at 250wv.
RE: GE H-632U Ballast Resistor Hytron K42B - by Radioroslyn - 03-27-2017, 06:05 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
