Simpson Handiscope
From what I can understand...most online sources seem to indicate that almost any modern 1X probe will work for these low frequency scopes...as long as the capacitance compensation range is correct.
I'm only planning on using it on old radios so high frequency testing isn't a concern.
Simpson Handiscope - by Tgace459 - 03-27-2017, 09:37 AM
RE: Simpson Handiscope - by Radioroslyn - 03-27-2017, 05:04 PM
RE: Simpson Handiscope - by Tgace459 - 03-27-2017, 06:43 PM
