Kirk's Majestic model 15.
Radio
http://www.radiomuseum.org/r/grigsby_gr_sherwood.html
Schematic
http://www.nostalgiaair.org/pagesbymodel...043933.pdf
Icon_smile
Kirk's Majestic model 15. - by morzh - 03-27-2017, 09:30 PM
RE: Kirk's Majestic model 15. - by Radioroslyn - 03-27-2017, 11:30 PM
RE: Kirk's Majestic model 15. - by Arran - 03-28-2017, 03:17 AM
RE: Kirk's Majestic model 15. - by OldRestorer - 03-28-2017, 05:02 AM
RE: Kirk's Majestic model 15. - by morzh - 03-28-2017, 01:55 PM
RE: Kirk's Majestic model 15. - by OldRestorer - 03-28-2017, 03:02 PM
RE: Kirk's Majestic model 15. - by morzh - 03-30-2017, 11:33 PM
RE: Kirk's Majestic model 15. - by OldRestorer - 03-31-2017, 04:22 AM
RE: Kirk's Majestic model 15. - by morzh - 03-31-2017, 05:13 PM
RE: Kirk's Majestic model 15. - by morzh - 03-31-2017, 09:17 PM
RE: Kirk's Majestic model 15. - by Arran - 04-01-2017, 02:41 AM
RE: Kirk's Majestic model 15. - by morzh - 04-01-2017, 11:38 AM
RE: Kirk's Majestic model 15. - by morzh - 04-01-2017, 05:08 PM
RE: Kirk's Majestic model 15. - by morzh - 04-02-2017, 02:48 PM
RE: Kirk's Majestic model 15. - by OldRestorer - 04-03-2017, 09:53 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
