Chassis ground
No, the chassis is not connected to the PS common which is the right side of the Power Switch and the electrolytics' minusses.
They are connected through the 1A capacitor as AC-coupled.
Chassis ground - by elfiself - 03-28-2017, 04:48 PM
RE: Chassis ground - by morzh - 03-28-2017, 05:21 PM
RE: Chassis ground - by elfiself - 03-28-2017, 07:36 PM
RE: Chassis ground - by morzh - 03-28-2017, 10:38 PM
RE: Chassis ground - by elfiself - 03-29-2017, 07:39 PM
RE: Chassis ground - by morzh - 03-29-2017, 09:59 PM
RE: Chassis ground - by Arran - 03-29-2017, 10:10 PM
RE: Chassis ground - by elfiself - 03-31-2017, 12:52 AM
RE: Chassis ground - by Arran - 03-31-2017, 04:02 AM
RE: Chassis ground - by elfiself - 04-01-2017, 05:26 PM
RE: Chassis ground - by morzh - 04-01-2017, 06:43 PM
RE: Chassis ground - by elfiself - 04-01-2017, 07:22 PM
RE: Chassis ground - by morzh - 04-01-2017, 07:40 PM
RE: Chassis ground - by elfiself - 01-09-2018, 12:40 PM
RE: Chassis ground - by Arran - 01-10-2018, 01:20 AM
RE: Chassis ground - by elfiself - 01-10-2018, 11:28 AM
RE: Chassis ground - by elfiself - 02-09-2018, 06:25 PM
RE: Chassis ground - by Radioroslyn - 02-09-2018, 08:39 PM
RE: Chassis ground - by jcassity - 02-11-2018, 12:53 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6385 online users. [Complete List]
» 1 Member(s) | 6384 Guest(s)
