Philco model 610 rebuild - by Tim P.
#46
Tim, I'm in the middle of a 610 rebuild and maybe you can help me out. There is a 32K resistor, #42, off of the filter can #41 that riders shows going to a mica #7 and pin 4 of the 6A7, grid 2. In my chassis the resistor goes to the mica and thats it. It does not connect to the 6A7. That grid only connects to the oscillator coil. I've looked and can't find a change that shows this connection. Is that how yours is wired?
Philco model 610 rebuild - by Tim P. - by TV MAN - 03-16-2014, 04:12 PM
RE: Philco model 610 rebuild - by Tim P. - by Jim Dutridge - 03-28-2017, 05:58 PM
The speaker table error?
Philco 70 antenna lead
