Help to Identify radio and parts
(03-29-2017, 03:48 PM)Radioroslyn Wrote:  Hi and welcome,
Think it's a model 14 code121. Here's a little cleaner diagram:  http://www.theoldradiofixerupperguy.com/...l14_91.pdf
Pretty dirty but that can be cleaned up. It's missing a #80 tube but don't need to run out and get as there some work to do beforehand.
Regarding the work to be done before I get a tube I know the first thing to do would be to replace the caps. In your expert opinion would you replace the wiring underneath as well?
Help to Identify radio and parts - by Anarchyswan - 03-29-2017, 08:44 AM
RE: Help to Identify radio and parts - by David - 03-29-2017, 02:50 PM
RE: Help to Identify radio and parts - by KCMike - 03-29-2017, 03:23 PM
RE: Help to Identify radio and parts - by Anarchyswan - 03-30-2017, 08:38 AM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4796 online users. [Complete List]
» 3 Member(s) | 4793 Guest(s)
