Threads: 5
City: Cedar Rapids Iowa
(03-30-2017, 01:10 PM)Mondial Wrote: As I understand it, your replacement transformer has a 6.3V winding for the tube heaters (filaments), but no 5V winding for the rectifier 5Y3GT. Is this correct? How did you have the present transformer connected to the heaters when the radio was working?
If you can't find a suitable transformer, you can use your present one by replacing the rectifier tube with silicon rectifier diodes and leaving the 5Y3GT tube with its socket wiring unconnected. It won't light up but will at least look original
Based on the way it was wired, it was missing the 2nd 6v (12v ct) secondary marked H (Heater?) on the schematic. The way I got around that 45 years ago when I replaced the transformer was to use the existing 6v secondary to drive the heater circuit and ground the other side of the heater. I also had replaced the rectifier tube with solid state diodes. I'd really like to put this back to the way it's supposed to be but will consider all options.
Thanks!
Rich
(This post was last modified: 03-30-2017, 02:58 PM by criageek.
Edit Reason: Incorrect facts
Users browsing this thread: 64 Guest(s)
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
