Chassis ground
Thank You Arran, I have been trying to find a basic explanation without much success. The terms B+, B- and where to establish the desired ground points arrow and rake are the source of my confusion. As far as the riveted resistor it was in fact isolated from chassis, there was however a chassis ground solder connection attached by one of the rivets securing the combo resister.
elfiself
Chassis ground - by elfiself - 03-28-2017, 04:48 PM
RE: Chassis ground - by morzh - 03-28-2017, 05:21 PM
RE: Chassis ground - by elfiself - 03-28-2017, 07:36 PM
RE: Chassis ground - by morzh - 03-28-2017, 10:38 PM
RE: Chassis ground - by elfiself - 03-29-2017, 07:39 PM
RE: Chassis ground - by morzh - 03-29-2017, 09:59 PM
RE: Chassis ground - by Arran - 03-29-2017, 10:10 PM
RE: Chassis ground - by elfiself - 03-31-2017, 12:52 AM
RE: Chassis ground - by Arran - 03-31-2017, 04:02 AM
RE: Chassis ground - by elfiself - 04-01-2017, 05:26 PM
RE: Chassis ground - by morzh - 04-01-2017, 06:43 PM
RE: Chassis ground - by elfiself - 04-01-2017, 07:22 PM
RE: Chassis ground - by morzh - 04-01-2017, 07:40 PM
RE: Chassis ground - by elfiself - 01-09-2018, 12:40 PM
RE: Chassis ground - by Arran - 01-10-2018, 01:20 AM
RE: Chassis ground - by elfiself - 01-10-2018, 11:28 AM
RE: Chassis ground - by elfiself - 02-09-2018, 06:25 PM
RE: Chassis ground - by Radioroslyn - 02-09-2018, 08:39 PM
RE: Chassis ground - by jcassity - 02-11-2018, 12:53 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6788 online users. [Complete List]
» 2 Member(s) | 6786 Guest(s)
