Isolation Transformer Output
I've got an old Triad N-67A transformer and the output is 128V. That seems a tad high and out of range of the 115 +/-5% spec. This seems too high to use for radio work and I'm wondering if it would work better through a variac that shouldn't be sensitive to 128V input. Anyone have experience with isolation transformer and their output?
Isolation Transformer Output - by g8wayg8r - 02-04-2010, 10:12 PM
Re: Isolation Transformer Output - by g8wayg8r - 02-06-2010, 12:46 PM
Re: Isolation Transformer Output - by codefox1 - 02-06-2010, 02:07 PM
Re: Isolation Transformer Output - by radiomikee - 02-08-2010, 11:42 PM
Re: Isolation Transformer Output - by g8wayg8r - 02-09-2010, 02:01 AM
New member
Philco 630csx power cord
New member
There are currently 4024 online users. [Complete List]
» 1 Member(s) | 4023 Guest(s)
