wire routing thoughts
With regards to how the wiring is routed under a chassis, yes it can make a difference. I had a Sparton AC/DC set that had a hum that would not go away, and after ruling out all of the usual suspects I noticed that some of the filament circuit wiring was routed parallel to the AVC wiring, so I rerouted the length of AVC wiring that was next to the heater wiring and solved the problem. It isn't often that the factory would make a mistake like this but in this case they did, as a rule anything with AC running through it is usually routed as close to the chassis as possible and as far away from the AVC or audio circuit wiring as possible as not to induce hum.
wire routing thoughts - by jcassity - 04-01-2017, 11:00 AM
RE: wire routing thoughts - by morzh - 04-01-2017, 11:26 AM
RE: wire routing thoughts - by David - 04-01-2017, 02:07 PM
RE: wire routing thoughts - by Mondial - 04-01-2017, 07:29 PM
RE: wire routing thoughts - by jcassity - 04-01-2017, 10:07 PM
RE: wire routing thoughts - by Arran - 04-02-2017, 12:52 AM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 7859 online users. [Complete List]
» 1 Member(s) | 7858 Guest(s)
