Kirk's Majestic model 15.
Aligned it by ear. It was pretty much there already. The station (local) seems to be where it should be. Since I have no escutcheon with the pointer I could only tell so accurate.
The radio is similar to a 90 with IF being 175kHz, plus 24A tubes make it even more similar, and so is the alignment, this one has no first RF having the 1st stage as the Det-Osc, so the alignment (to which I had no documents) went with the generator connected to the grid of the 1st Det-osc at IF frequency.
The sound....well, plate detector..no AVC... Should I say more?
Anyway, done with it.
REST!!!!
Kirk's Majestic model 15. - by morzh - 03-27-2017, 09:30 PM
RE: Kirk's Majestic model 15. - by Radioroslyn - 03-27-2017, 11:30 PM
RE: Kirk's Majestic model 15. - by Arran - 03-28-2017, 03:17 AM
RE: Kirk's Majestic model 15. - by OldRestorer - 03-28-2017, 05:02 AM
RE: Kirk's Majestic model 15. - by morzh - 03-28-2017, 01:55 PM
RE: Kirk's Majestic model 15. - by OldRestorer - 03-28-2017, 03:02 PM
RE: Kirk's Majestic model 15. - by morzh - 03-30-2017, 11:33 PM
RE: Kirk's Majestic model 15. - by OldRestorer - 03-31-2017, 04:22 AM
RE: Kirk's Majestic model 15. - by morzh - 03-31-2017, 05:13 PM
RE: Kirk's Majestic model 15. - by morzh - 03-31-2017, 09:17 PM
RE: Kirk's Majestic model 15. - by Arran - 04-01-2017, 02:41 AM
RE: Kirk's Majestic model 15. - by morzh - 04-01-2017, 11:38 AM
RE: Kirk's Majestic model 15. - by morzh - 04-01-2017, 05:08 PM
RE: Kirk's Majestic model 15. - by morzh - 04-02-2017, 02:48 PM
RE: Kirk's Majestic model 15. - by OldRestorer - 04-03-2017, 09:53 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
