90 /w/ 1-47...need help
A simple ohmmeter test is the first step. If zero resistance, the connection should be OK. Otherwise running a jumper to a known good ground is required.
Don
90 /w/ 1-47...need help - by bdi1976 - 04-01-2017, 05:01 PM
RE: 90 /w/ 1-47...need help - by morzh - 04-01-2017, 06:47 PM
RE: 90 /w/ 1-47...need help - by Mondial - 04-01-2017, 06:58 PM
RE: 90 /w/ 1-47...need help - by bdi1976 - 04-01-2017, 10:39 PM
RE: 90 /w/ 1-47...need help - by Radioroslyn - 04-01-2017, 11:32 PM
RE: 90 /w/ 1-47...need help - by 45philcodon - 04-02-2017, 04:29 PM
RE: 90 /w/ 1-47...need help - by bdi1976 - 04-02-2017, 08:46 PM
RE: 90 /w/ 1-47...need help - by 45philcodon - 04-03-2017, 12:37 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
