Stromberg Carlson model 60
Thanks Arran. That's the factory folder I'll be using. I plan to restuff the numbered paper caps and restore the underside of chassis to original as possible.
Not sure what to do about the Philco pots that is it right now. I did do a test power up with an extra parts speaker not original. Missing the original speaker darn it .
I got sound and could hear a station barely in the back ground. So it was time to dig into it.
[Image: http://i1336.photobucket.com/albums/o654...yfrcyh.jpg]
Got to start somewhere so decided to start with the bypass can assembly.
Hard to believe they got ten caps in the little can. Going to be a little tricky to restuff.
[Image: http://i1336.photobucket.com/albums/o654...jatxct.jpg]
Stromberg Carlson model 60 - by KCMike - 04-02-2017, 07:05 PM
RE: Stromberg Carlson model 60 - by Arran - 04-03-2017, 04:05 AM
RE: Stromberg Carlson model 60 - by KCMike - 04-03-2017, 01:40 PM
RE: Stromberg Carlson model 60 - by Radioroslyn - 04-04-2017, 06:03 AM
RE: Stromberg Carlson model 60 - by Arran - 04-04-2017, 10:47 PM
RE: Stromberg Carlson model 60 - by KCMike - 04-05-2017, 05:11 PM
RE: Stromberg Carlson model 60 - by KCMike - 04-08-2017, 01:15 PM
RE: Stromberg Carlson model 60 - by Joe Rossi - 04-09-2017, 08:46 PM
RE: Stromberg Carlson model 60 - by KCMike - 04-10-2017, 09:58 AM
RE: Stromberg Carlson model 60 - by Eric - 06-06-2018, 09:20 AM
RE: Stromberg Carlson model 60 - by KCMike - 06-06-2018, 12:18 PM
RE: Stromberg Carlson model 60 - by Eric - 06-06-2018, 07:25 PM
RE: Stromberg Carlson model 60 - by Eric - 06-14-2018, 04:12 PM
RE: Stromberg Carlson model 60 - by KCMike - 06-14-2018, 04:37 PM
RE: Stromberg Carlson model 60 - by Eric - 06-14-2018, 05:53 PM
There are currently 8720 online users. [Complete List]
» 1 Member(s) | 8719 Guest(s)
