TrueTone Model D9?
>Do you think the old A and B batteries are critical for normal operation?
Well depends. If you plan on operating from batteries yes it will.
For ac operation no it doesn't.
TrueTone Model D9? - by WallaceRoger - 03-29-2017, 08:33 PM
RE: TrueTone Model D9? - by KCMike - 03-29-2017, 09:15 PM
RE: TrueTone Model D9? - by Arran - 03-29-2017, 10:50 PM
RE: TrueTone Model D9? - by WallaceRoger - 03-30-2017, 09:45 PM
RE: TrueTone Model D9? - by David - 03-31-2017, 07:57 PM
RE: TrueTone Model D9? - by Arran - 04-01-2017, 02:46 AM
RE: TrueTone Model D9? - by WallaceRoger - 04-03-2017, 04:20 PM
RE: TrueTone Model D9? - by Arran - 04-04-2017, 04:26 AM
RE: TrueTone Model D9? - by Radioroslyn - 04-03-2017, 10:56 PM
RE: TrueTone Model D9? - by Radioroslyn - 04-04-2017, 05:43 AM
RE: TrueTone Model D9? - by WallaceRoger - 04-04-2017, 03:07 PM
RE: TrueTone Model D9? - by WallaceRoger - 04-04-2017, 03:18 PM
RE: TrueTone Model D9? - by WallaceRoger - 04-30-2017, 12:26 PM
RE: TrueTone Model D9? - by WallaceRoger - 05-01-2017, 01:37 PM
RE: TrueTone Model D9? - by Eliot Ness - 05-01-2017, 02:03 PM
RE: TrueTone Model D9? - by WallaceRoger - 05-01-2017, 08:48 PM
RE: TrueTone Model D9? - by WallaceRoger - 07-24-2017, 09:36 PM
TrueTone Model D9 - by WallaceRoger - 08-08-2017, 10:44 PM
RE: TrueTone Model D9? - by Arran - 08-09-2017, 03:31 AM
RE: TrueTone Model D9? - by Paul Philco322 - 08-15-2017, 08:43 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6735 online users. [Complete List]
» 1 Member(s) | 6734 Guest(s)
