  • 1 Vote(s) - 1 Average
General Restoration Questions
So you suggest sealing before grain filling? I've always grain filled and stained before sealing. Ill have to try your method and see how it works.
I typically use a water based filler.
General Restoration Questions - by Tgace459 - 04-05-2017, 09:20 AM
RE: General Restoration Questions - by Tgace459 - 04-06-2017, 07:56 AM
RE: General Restoration Questions - by klondike98 - 04-06-2017, 01:27 PM
RE: General Restoration Questions - by Phlogiston - 04-12-2017, 01:19 PM
RE: General Restoration Questions - by Tgace459 - 04-14-2017, 01:54 PM
RE: General Restoration Questions - by Phlogiston - 04-14-2017, 05:16 PM
RE: General Restoration Questions - by Tgace459 - 04-14-2017, 05:24 PM
RE: General Restoration Questions - by Phlogiston - 04-14-2017, 07:17 PM
RE: General Restoration Questions - by Tgace459 - 04-25-2017, 12:21 PM
RE: General Restoration Questions - by Tgace459 - 04-25-2017, 02:46 PM
RE: General Restoration Questions - by Tgace459 - 04-25-2017, 03:14 PM
RE: General Restoration Questions - by Tgace459 - 04-26-2017, 11:36 AM
Eico 232 VTVM Schematic
There are currently 6514 online users. [Complete List]
» 2 Member(s) | 6512 Guest(s)
