Philco 660 antenna transformer
(04-06-2017, 04:06 PM)Gotte Wrote:  I sent Gary as message, he thought I could replace the defective section, I can't see how that can be done unless you get real lucky and can spot a broken winding on the surface of the coil and I can't
see anything broken..I'm hoping that he can help me out , I don't know Gary but hoping for the best. I also found that a Philco 665 uses the same coil..thanks for your help...Gus
Your pretty much stuck with using a coil from a 660 or 665. I believe that the 37 models are different. The 116 coil is close but has a little different coverage. Primary has a bunch of taps so it's going to be no walk in the park to rewind.
Philco 660 antenna transformer - by Gotte - 04-05-2017, 02:15 PM
RE: Philco 660 antenna transformer - by KCMike - 04-05-2017, 06:40 PM
RE: Philco 660 antenna transformer - by Gotte - 04-06-2017, 04:06 PM
RE: Philco 660 antenna transformer - by Radioroslyn - 04-06-2017, 11:08 PM
RE: Philco 660 antenna transformer - by morzh - 04-06-2017, 04:19 PM
RE: Philco 660 antenna transformer - by Gotte - 05-01-2017, 08:03 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 5031 online users. [Complete List]
» 3 Member(s) | 5028 Guest(s)
