Sparks Withington 581X
Don't worry about that IF rejection coil. You can just remove it completely.
The original purpose of L1 and C3 was to serve as a trap to eliminate interference from high power marine radio stations which were in operation at the time when the radio was built. These stations operated in the LF band at frequencies around 400-500 kHz, and could cause interference at the IF frequency when picked up by the antenna. Today these stations no longer exist, and therefore the rejection circuit is no longer needed.
Sparks Withington 581X - by Joe Rossi - 11-04-2016, 09:55 PM
RE: Sparks Withington 581X - by klondike98 - 11-05-2016, 09:32 AM
RE: Sparks Withington 581X - by Paul Philco322 - 11-05-2016, 10:53 AM
RE: Sparks Withington 581X - by Joe Rossi - 11-05-2016, 11:29 AM
RE: Sparks Withington 581X - by OldRestorer - 11-06-2016, 07:17 PM
RE: Sparks Withington 581X - by Arran - 11-07-2016, 05:05 AM
RE: Sparks Withington 581X - by Joe Rossi - 11-07-2016, 10:19 PM
RE: Sparks Withington 581X - by Paul Philco322 - 11-07-2016, 10:47 PM
RE: Sparks Withington 581X - by Arran - 11-08-2016, 06:18 AM
RE: Sparks Withington 581X - by Joe Rossi - 11-08-2016, 09:52 AM
RE: Sparks Withington 581X - by Joe Rossi - 04-09-2017, 06:20 PM
RE: Sparks Withington 581X - by Mondial - 04-09-2017, 07:27 PM
RE: Sparks Withington 581X - by Joe Rossi - 04-09-2017, 08:33 PM
RE: Sparks Withington 581X - by Arran - 04-10-2017, 04:00 AM
RE: Sparks Withington 581X - by Joe Rossi - 04-10-2017, 08:22 PM
RE: Sparks Withington 581X - by Joe Rossi - 10-21-2017, 06:17 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
