38-690 grille cloth replacement?
Just aquired a pair of 38-690's. Both of them have deteriorated grille cloth that is in no way salvagable...Does anyone know if the "Philco Ribbed" cloth from Radio Daze is a correct replacement?
http://www.radiodaze.com/grille-cloth-14-item-grc14/
38-690 grille cloth replacement? - by sdradioman - 04-11-2017, 09:05 PM
