Philco 38-690 electronics restoration.
Power transformer is down on the bottom chassis too isn't it?
Philco 38-690 electronics restoration. - by morzh - 04-12-2017, 08:19 PM
RE: Philco 38-690 electronics restoration. - by Radioroslyn - 04-12-2017, 11:25 PM
Users browsing this thread: 15 Guest(s)
The speaker table error?
Philco 70 antenna lead
