Philco 38-690 electronics restoration.
(04-12-2017, 08:19 PM)morzh Wrote: It is missing the bottom cover. I know it should have one as 37-116 does and they are very similar.
I do have an extra 37-116 chassis and if it has the cover abd it fits, I'll use it.
It won't fit. The 38-690 tuner chassis is smaller than the 37/38-116 chassis.
I've never seen a cover on a 38-690 tuner chassis. It doesn't really need one as it sits on a wood shelf. On the other hand, the 37-116 chassis only rests on front and back supports, and so most of the chassis is exposed at the bottom, hence the chassis bottom cover.
RE: Philco 38-690 electronics restoration. - by Ron Ramirez - 04-13-2017, 10:29 AM
Users browsing this thread: 36 Guest(s)
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
There are currently 5975 online users. [Complete List] » 1 Member(s) | 5974 Guest(s)
