Philco 38-690 electronics restoration.
Does look like it. Another reason for the chassis to be lighter. It helps - the chassis is barely manageable when it has the transformer. On the other hand, the bottom one is much smaller and despite the two transformers will be much easier to turn around.
Ron
thanks, you put my mind to rest. I was wondering about it and thought the cover might be there for EMI reasons, though other Philcos do not have them, but then who know how a complex chassis behaves. So the cover was there mainly for the safety so no one sticks their fingers inside when it is open.
I take it, then 38-116 does not have the cover either? It is also inclined and rests on a full board.
Philco 38-690 electronics restoration. - by morzh - 04-12-2017, 08:19 PM
RE: Philco 38-690 electronics restoration. - by morzh - 04-13-2017, 11:12 AM
Users browsing this thread: 31 Guest(s)
The speaker table error?
Philco 70 antenna lead
There are currently 6866 online users. [Complete List]
» 2 Member(s) | 6864 Guest(s)
