Realistic model 12-1350B FM converter
I've done all that, I had to put in a new antenna lead because the old one was cut out when I bought the thing.
http://rs32.pbsrc.com/albums/d5/flathead...0&fit=clip
Here's a link to a photo of the unit. You can kind of see where I soldered the lead into the board coming from the white sheathing, but under that you can also kind of see a wire coming from the board. It was connected to something otherwise it shouldn't be there. Wish I could see inside another to see where it should go.
RE: Realistic model 12-1350B FM converter - by flatheadjr - 04-14-2017, 09:58 PM
