Gonset Communicator lll
Good Question.. No Clue.. The power plug from the power supply and the one on TX that it adapts to look original as far as I can tell. Maybe there is another set of schematics out there.. Not sure..
I will take a couple of more pictures of both connectors..
Skip...
Gonset Communicator lll - by vecher - 04-02-2017, 12:05 AM
RE: Gonset Communicator lll - by Arran - 04-02-2017, 12:57 AM
RE: Gonset Communicator lll - by Joe Rossi - 04-09-2017, 06:31 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-09-2017, 07:27 PM
RE: Gonset Communicator lll - by vecher - 04-09-2017, 07:55 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-09-2017, 09:29 PM
RE: Gonset Communicator lll - by Arran - 04-10-2017, 03:51 AM
RE: Gonset Communicator lll - by vecher - 04-11-2017, 12:14 AM
RE: Gonset Communicator lll - by Radioroslyn - 04-11-2017, 07:26 AM
RE: Gonset Communicator lll - by vecher - 04-11-2017, 10:03 AM
RE: Gonset Communicator lll - by Mondial - 04-12-2017, 12:57 PM
RE: Gonset Communicator lll - by vecher - 04-12-2017, 11:44 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-15-2017, 04:04 PM
RE: Gonset Communicator lll - by vecher - 04-13-2017, 08:07 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-15-2017, 04:05 PM
RE: Gonset Communicator lll - by vecher - 04-15-2017, 04:59 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-15-2017, 06:09 PM
RE: Gonset Communicator lll - by vecher - 04-15-2017, 07:56 PM
RE: Gonset Communicator lll - by vecher - 04-15-2017, 08:09 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-15-2017, 08:15 PM
RE: Gonset Communicator lll - by vecher - 04-15-2017, 08:20 PM
RE: Gonset Communicator lll - by vecher - 04-15-2017, 08:44 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-15-2017, 09:03 PM
RE: Gonset Communicator lll - by vecher - 04-15-2017, 10:13 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-15-2017, 10:32 PM
RE: Gonset Communicator lll - by vecher - 04-16-2017, 01:29 AM
RE: Gonset Communicator lll - by Radioroslyn - 04-16-2017, 10:14 AM
RE: Gonset Communicator lll - by Radioroslyn - 04-16-2017, 11:36 AM
RE: Gonset Communicator lll - by vecher - 04-16-2017, 01:04 PM
RE: Gonset Communicator lll - by vecher - 04-16-2017, 02:34 PM
RE: Gonset Communicator lll - by vecher - 04-16-2017, 10:34 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-16-2017, 10:49 PM
RE: Gonset Communicator lll - by vecher - 04-16-2017, 11:26 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-17-2017, 12:12 AM
RE: Gonset Communicator lll - by vecher - 04-17-2017, 07:39 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-17-2017, 07:51 PM
RE: Gonset Communicator lll - by vecher - 04-19-2017, 11:13 PM
RE: Gonset Communicator lll - by Radioroslyn - 04-20-2017, 12:11 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
