40-180 veneer
Thanks Arran,
Can you tell me what the difference is between plain vs quarter cut type and a possible supplier ?
Thank you,
Jerry
40-180 veneer - by jeryb - 04-14-2017, 06:24 PM
RE: 40-180 veneer - by Arran - 04-15-2017, 11:14 PM
RE: 40-180 veneer - by jeryb - 04-15-2017, 11:22 PM
RE: 40-180 veneer - by John Bartley - 04-16-2017, 08:59 AM
RE: 40-180 veneer - by jeryb - 04-17-2017, 12:24 AM
RE: 40-180 veneer - by Arran - 04-17-2017, 10:11 PM
RE: 40-180 veneer - by jeryb - 04-17-2017, 10:51 PM
RE: 40-180 veneer - by Arran - 04-18-2017, 12:36 AM
RE: 40-180 veneer - by Steve Davis - 04-17-2017, 11:48 PM
RE: 40-180 veneer - by Mondial - 04-18-2017, 08:47 AM
