40-180 veneer
On flat (plain) sawn wood you can see the "face" grain.  On true quarter sawn wood you can see the growth rings.
Here's an example of two cuts ("slab" = flat or plain) :
[Image: http://d2vhprqki2fot3.cloudfront.net/exp...qsawn2.jpg]
40-180 veneer - by jeryb - 04-14-2017, 06:24 PM
RE: 40-180 veneer - by Arran - 04-15-2017, 11:14 PM
RE: 40-180 veneer - by jeryb - 04-15-2017, 11:22 PM
RE: 40-180 veneer - by John Bartley - 04-16-2017, 08:59 AM
RE: 40-180 veneer - by jeryb - 04-17-2017, 12:24 AM
RE: 40-180 veneer - by Arran - 04-17-2017, 10:11 PM
RE: 40-180 veneer - by jeryb - 04-17-2017, 10:51 PM
RE: 40-180 veneer - by Arran - 04-18-2017, 12:36 AM
RE: 40-180 veneer - by Steve Davis - 04-17-2017, 11:48 PM
RE: 40-180 veneer - by Mondial - 04-18-2017, 08:47 AM
Eico 232 VTVM Schematic
There are currently 10008 online users. [Complete List]
» 1 Member(s) | 10007 Guest(s)
