Threads: 20
City: Orland Park
State, Province, Country: Illiinois
I'm making slow but sure progress, mostly waiting for the capacitor and resistor assortments I bought on ebay to arrive. I rebuilt a couple of the easiest capacitors and now I've pulled out part #8 bakelite capacitor of .05mfd , which the parts list notes as also containing a 250ohm resistor. I haven't cleaned the old tarry gunk out yet. Is there really a resistor inside here? I'm assuming a regular old 1 watt metal film resistor is fine?
EDIT: Yep, I found it. Heating up the bakelite block with a heat gun and pushing through a rivet hold with an old 1/16 drill bit got it out nice and easy. I kind of messed up and now trying to figure out what the other end of the resistor attached to...
Greg
(This post was last modified: 04-16-2017, 08:36 PM by WallaceRoger.
Edit Reason: update
RE: Philco Model 20 Lowboy - by WallaceRoger - 04-16-2017, 05:03 PM
Users browsing this thread: 15 Guest(s)
91H Code 126 Restore
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
Philco 70 antenna lead
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.Jim Dutridge — 04:34 PM |
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
There are currently 3730 online users. [Complete List] » 2 Member(s) | 3728 Guest(s)
