Reproduce Tube Layout Paper Labels?
The 70 Chassis is cleaned and painted and looks good but I haven't done anything to tube shield yet; it could also use a coat of paint as it has rust. The paint will be a darker gray and I think I will try a hammered finish. Problem is; It has a tattered tube layout label that has a couple of corners missing. Does anyone make repro labels; or what is best way to go about maybe printing one and using adhesive to apply to the new paint surface? Ron, sorry if maybe this is better in another forum . Thanks Bill
Reproduce Tube Layout Paper Labels? - by Guest - 01-10-2010, 11:38 AM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
