GE A-70 vernier operation
I solved this issue by adjusting the three clamping screws to get the proper preload on the ball bearings. I had the screws tightened down too much. The tab does indeed need to be in the slot to prevent rotation of the vernier body and then the screws adjusted for proper operation. This vernier control is intuitive and works very well when adjusted properly.
Steve D
GE A-70 vernier operation - by Steve D - 04-10-2017, 11:40 AM
RE: GE A-70 vernier operation - by KCMike - 04-10-2017, 02:48 PM
RE: GE A-70 vernier operation - by Steve D - 04-11-2017, 05:28 PM
RE: GE A-70 vernier operation - by Steve D - 04-19-2017, 05:06 PM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4803 online users. [Complete List]
» 2 Member(s) | 4801 Guest(s)
