crosley model 148 cap question
Thanks Greg and Terry.
Hooked it up and it works great.
Such great people on here willing to help.
Have a great night guys,
Murf
crosley model 148 cap question - by murf - 04-19-2017, 09:16 PM
RE: crosley model 148 cap question - by gregb - 04-19-2017, 09:48 PM
RE: crosley model 148 cap question - by murf - 04-19-2017, 10:25 PM
RE: crosley model 148 cap question - by murf - 04-19-2017, 11:02 PM
RE: crosley model 148 cap question - by gregb - 04-19-2017, 11:09 PM
RE: crosley model 148 cap question - by murf - 04-19-2017, 11:29 PM
RE: crosley model 148 cap question - by murf - 04-20-2017, 03:59 PM
RE: crosley model 148 cap question - by gregb - 04-20-2017, 07:00 PM
RE: crosley model 148 cap question - by murf - 04-20-2017, 07:24 PM
RE: crosley model 148 cap question - by murf - 04-20-2017, 08:45 PM
RE: crosley model 148 cap question - by David - 04-20-2017, 08:56 PM
RE: crosley model 148 cap question - by murf - 04-20-2017, 10:00 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
