It is time: The Fisher TA-600
Threads: 54
(04-20-2017, 10:01 PM)morzh Wrote: BTW, the tubes you've gotten are from Saratov tube factory "Reflector".
They are still very much in business, although they changed the name apparently, that's where the Sovtek branded tubes are made, as well as the fake Svetlana tubes that New Sensor was pedaling in the U.S market.
(This post was last modified: 04-20-2017, 11:36 PM by Arran.)
RE: It is time: The Fisher TA-600 - by Arran - 04-20-2017, 11:31 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
