Philco 37-630, Low volume, 1st IF problems??
The black wires are a negative feedback winding which was added in later production. It applies an out of phase IF signal to the suppressor grid of the 6K7 tube and serves to stabilize the IF amp. I guess Philco had problems with the IF stage oscillating and came up with the extra winding as a fix. Don't think it has anything to do with your problem unless it is obviously shorted to the secondary winding itself.
It seems that the secondary of the IF trans is not resonating with the associated trimmer and that will definitely cause low sensitivity. Have you measured the actual resistance of the secondary and how does it compare to the value noted on the schematic?
There is not much there to the tuned circuit, so there is a problem with either the coil, or the mica compression trimmer which tunes it to resonance. You can disconnect the coil winding from the trimmer and test each individually.
RE: Philco 37-630, Low volume, 1st IF problems?? - by Mondial - 04-23-2017, 07:54 PM
Ooh, very nice!jrblasde — 12:19 PM
I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye. It has 13 tu...Dan Walker — 12:07 PM
Hi guys! I’m a new member here but have been using your resources for quite some time. Hopefully I can get some help wit...Radios1340 — 11:52 AM
There are currently 9248 online users. [Complete List]
» 2 Member(s) | 9246 Guest(s)
