  • 1 Vote(s) - 1 Average
General Restoration Questions
After applying Crystallac grain fill and sanding/sealing/sanding I wound up with this discoloration.
[Image: https://i.imgur.com/fTfdP2e.jpg]
Is this something you think toner will even out? Or am I screwed into a redo?
General Restoration Questions - by Tgace459 - 04-05-2017, 09:20 AM
RE: General Restoration Questions - by Tgace459 - 04-06-2017, 07:56 AM
RE: General Restoration Questions - by klondike98 - 04-06-2017, 01:27 PM
RE: General Restoration Questions - by Phlogiston - 04-12-2017, 01:19 PM
RE: General Restoration Questions - by Tgace459 - 04-14-2017, 01:54 PM
RE: General Restoration Questions - by Phlogiston - 04-14-2017, 05:16 PM
RE: General Restoration Questions - by Tgace459 - 04-14-2017, 05:24 PM
RE: General Restoration Questions - by Phlogiston - 04-14-2017, 07:17 PM
RE: General Restoration Questions - by Tgace459 - 04-25-2017, 12:21 PM
RE: General Restoration Questions - by Tgace459 - 04-25-2017, 02:46 PM
RE: General Restoration Questions - by Tgace459 - 04-25-2017, 03:14 PM
RE: General Restoration Questions - by Tgace459 - 04-26-2017, 11:36 AM
Eico 232 VTVM Schematic
There are currently 9268 online users. [Complete List]
» 1 Member(s) | 9267 Guest(s)
