Radio Identification Help Needed Please
Hi, thank you for the reply. I am not sure about the tubes I have contacted my friend to find out about the tubes. It does look from the pictures like a nice piece of furniture. So am I clear on this that this is probably just a speaker table? So the radio would have sit on top of the piece and appears to be missing? Thank you, bigodg
Re: Radio Identification Help Needed Please - by bigdog - 01-14-2010, 01:57 PM
