Philco 60 question
The 60 is a bad example of that question. As I recall it went through some major changes, like removing a trimmer and adding a wave trap that would be hard to bring an older run "up to date". But as far as some of my other Philcos, I have made updates based on the run change notes - if it made sense. Like they changed a resistor value to improve oscillation or something. But not in cases where it would require adding some parts that would be hard to source or no apparent benefit.
Really it's up to you. But if it's simply changing the value of a resistor or cap to improve performance or correct an issue per the notes, I see no harm in doing so. Especially since I like to use my radios, not just park them on a shelf.
Philco 60 question - by Kestas - 04-26-2017, 10:17 AM
RE: Philco 60 question - by klondike98 - 04-26-2017, 11:15 AM
RE: Philco 60 question - by Nick3092 - 04-26-2017, 12:00 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
