Philco 43
Hi John,
If you find no bites on your request and you don't mind doing a little experimenting try this. From the diagram it looks like the missing coil is used to couple some of the oscillator signal up to the ant circuit. It's untuned so I'm thinking that the inductances aren't very critical. I would wind a coil that mimics the primary of the oscillator coil #10. Might be a start as the set won't do anything w/o the center winding on the missing coil as it the ground return for the mixer cathode.
Philco 43 - by vintageradiojohn - 04-28-2017, 08:24 PM
RE: Philco 43 - by morzh - 04-28-2017, 10:18 PM
RE: Philco 43 - by Radioroslyn - 04-28-2017, 10:48 PM
RE: Philco 43 - by morzh - 04-29-2017, 03:32 PM
RE: Philco 43 - by Radioroslyn - 04-29-2017, 04:15 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 7505 online users. [Complete List]
» 1 Member(s) | 7504 Guest(s)
