46-1226 code 125 restoratioin *DONE
Threads: 46
City: Gap Mills Wv 24941
now you can see i went from what would be considred a good original replacement choice by the "numbers" but in practice it failed.
my blue 300 ohm was porcelain design.
my green 500 ohm is porcelain and hollow in design with my fabricated heat sync & inserted copper tubuing in the center.
I believe my 500ohm solution is probably 5 times larger in size and should suit the application but it does not.
I suspect that :
A- i still have a problem somewhere like someone said earlier or.....
B- the circuit is talking to me, telling me i need to actually be somwhere in the 120w range.
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 08:12 AM
Users browsing this thread: 60 Guest(s)
Part 4 of this series now uploaded
link below to anyone interested
Buzz — 02:39 PM |
Welcome to the Phorum, Radios1340! The oscillator coil on the 60 is a common culprit. I just bought a 60B (June 1934) ...GarySP — 02:33 PM |
Yes, standard alignment procedure. I can get the minuscule tone to vary when adjusting the trimmers. But you almost have...Radios1340 — 01:40 PM |
An imposing-looking radio, for sure.morzh — 12:43 PM |
Model 60 struck again :lol:
Welcome to the Phorum!
Above is the article on Model 60. Could be of some use.
Now...morzh — 12:38 PM |
Ooh, very nice!jrblasde — 12:19 PM |
I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye.
It has 13 tu...Dan Walker — 12:07 PM |
Hi guys! I’m a new member here but have been using your resources for quite some time. Hopefully I can get some help wit...Radios1340 — 11:52 AM |
Milkjug plastic?morzh — 09:36 PM |
Yep.
'Cause when I heard "buibble" I immediately thought of this
and started wondering how this poly...morzh — 09:33 PM |
There are currently 8298 online users. [Complete List] » 2 Member(s) | 8296 Guest(s)
