Philco 38-690 electronics restoration.
Threads: 271
City: Wilsonville
State, Province, Country: OR
yes, morzh stuffed new caps inside the old shell of the paper cap to keep the original look. This restuffing technique takes a fair amount of extra work so most folks for most radios don't do it. you warm up the old cap and pull the guts out of it leaving the paper/cardboard tube. A new cap is inserted and then refilled with something like hot glue. Some use old was pulled from old caps or new wax with the brown coloration.
RE: Philco 38-690 electronics restoration. - by klondike98 - 04-30-2017, 10:32 AM
Users browsing this thread: 17 Guest(s)
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
