  • 3 Vote(s) - 4 Average
Stratosphere 1000Z Restoration
Updates on the Power/amp chassis including rebuilding the original filters.
At this point it might be usefull to reference the earlier project:
http://www.russoldradios.com/blog/into-the-stratosphere
Stratosphere 1000Z Restoration - by Phlogiston - 04-16-2017, 02:41 PM
RE: Stratosphere 1000Z Restoration - by morzh - 04-16-2017, 03:14 PM
RE: Stratosphere 1000Z Restoration - by gregb - 04-16-2017, 08:12 PM
RE: Stratosphere 1000Z Restoration - by morzh - 04-20-2017, 11:42 AM
RE: Stratosphere 1000Z Restoration - by Phlogiston - 04-30-2017, 01:22 PM
RE: Stratosphere 1000Z Restoration - by morzh - 05-30-2017, 01:52 PM
RE: Stratosphere 1000Z Restoration - by KCMike - 06-02-2017, 11:09 AM
RE: Stratosphere 1000Z Restoration - by TV MAN - 06-05-2017, 11:13 PM
RE: Stratosphere 1000Z Restoration - by gregb - 06-11-2017, 02:03 PM
RE: Stratosphere 1000Z Restoration - by morzh - 06-12-2017, 03:06 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6222 online users. [Complete List]
» 1 Member(s) | 6221 Guest(s)
