Masterpeice V Correct?
http://www.radiomuseum.org/r/mcmurdo_masterpiece_v.html
Is this listing correct? In particular the picture of the 2 12" Jensens + tweeter mounted on a new looking baffle. And the text that also mentions the 2 Jensens?
I have been told that this may have been correct for the MPIV but the only speaker for the MPV was the 18" Jensen.
Masterpeice V Correct? - by Phlogiston - 05-01-2017, 05:40 PM
RE: Masterpeice V Correct? - by Ron Ramirez - 05-01-2017, 08:39 PM
RE: Masterpeice V Correct? - by Phlogiston - 05-01-2017, 10:53 PM
RE: Masterpeice V Correct? - by Ron Ramirez - 05-02-2017, 08:54 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
