  • 1 Vote(s) - 4 Average
46-1226 code 125 restoratioin *DONE
Something is wrong with the connection of the green center tap wire.
 It should not connect to ground, but to the end of R100. You should measure 271 ohms from the center tap to chassis ground. You should also read 271 ohms from the can (negative) connection of C101 to chassis.
Confirm that you so not have a short from the green center tap wire or C101 negative terminal to the chassis.
46-1226 code 125 restoratioin *DONE - by jcassity - 03-19-2017, 11:03 AM
RE: 46-1226 code 125 restoratioin - by klondike98 - 03-19-2017, 01:57 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-19-2017, 06:31 PM
RE: 46-1226 code 125 restoratioin - by David - 03-20-2017, 07:52 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 03-20-2017, 10:11 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 11:02 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 11:07 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 11:09 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-23-2017, 09:18 PM
RE: 46-1226 code 125 restoratioin - by Arran - 03-24-2017, 12:24 AM
RE: 46-1226 code 125 restoratioin - by morzh - 03-24-2017, 10:11 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-24-2017, 10:45 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-28-2017, 12:47 PM
RE: 46-1226 code 125 restoratioin - by sam - 03-28-2017, 01:44 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-30-2017, 08:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-31-2017, 01:20 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-31-2017, 01:32 PM
RE: 46-1226 code 125 restoratioin - by David - 03-31-2017, 07:46 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-04-2017, 09:39 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-03-2017, 03:12 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-04-2017, 12:03 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-03-2017, 09:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-04-2017, 10:24 PM
RE: 46-1226 code 125 restoratioin - by Arran - 04-04-2017, 11:15 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-05-2017, 02:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-06-2017, 10:05 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-06-2017, 04:33 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-07-2017, 10:21 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-08-2017, 01:49 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-13-2017, 09:30 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-14-2017, 07:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-15-2017, 10:32 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-15-2017, 10:42 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-15-2017, 12:13 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 09:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 10:00 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-16-2017, 10:30 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 10:13 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-17-2017, 06:36 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-17-2017, 08:30 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-19-2017, 08:19 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 08:54 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 04:49 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 10:06 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-20-2017, 09:24 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-20-2017, 09:30 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 09:56 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 10:04 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 10:08 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 10:33 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 10:49 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 11:31 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-21-2017, 12:40 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 12:55 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-21-2017, 12:59 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 09:35 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 08:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 09:00 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 09:05 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 06:25 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 06:32 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-22-2017, 07:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 10:13 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 10:15 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-22-2017, 10:22 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-22-2017, 11:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-23-2017, 09:38 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-23-2017, 10:34 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-23-2017, 10:53 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-24-2017, 08:34 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-25-2017, 03:44 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-25-2017, 06:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-25-2017, 06:12 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-26-2017, 11:06 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-27-2017, 06:52 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 10:06 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 06:41 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-28-2017, 09:44 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-28-2017, 10:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 10:49 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 11:17 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 02:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 03:17 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-29-2017, 03:18 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 03:40 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-29-2017, 04:41 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 04:43 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-29-2017, 06:10 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 08:11 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 08:53 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-29-2017, 08:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 09:42 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 09:52 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 09:53 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-30-2017, 12:19 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 07:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 08:12 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 08:18 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 08:36 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 09:27 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-30-2017, 10:20 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-30-2017, 11:56 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 10:36 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 11:36 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 11:53 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 10:27 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 08:31 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 09:05 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 09:07 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 09:16 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 09:18 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 09:27 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 09:47 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 09:53 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 01:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 02:40 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 02:50 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-02-2017, 03:13 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 03:16 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 04:10 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 04:19 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-02-2017, 05:31 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 05:31 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 07:23 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 07:36 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-03-2017, 08:58 AM
RE: 46-1226 code 125 restoratioin - by criageek - 05-03-2017, 12:23 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-04-2017, 10:02 AM
RE: 46-1226 code 125 restoratioin - by morzh - 05-04-2017, 10:16 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 10:02 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 07:45 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-05-2017, 09:48 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 10:50 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-05-2017, 10:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-06-2017, 10:51 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-06-2017, 02:25 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 11:21 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 11:26 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 11:33 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 11:37 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 09:47 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-07-2017, 11:00 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 06:47 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 06:49 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 10:30 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-10-2017, 10:19 AM
RE: 46-1226 code 125 restoratioin - by morzh - 05-10-2017, 11:54 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-10-2017, 12:32 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 10:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 10:15 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 10:28 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-13-2017, 04:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-15-2017, 08:09 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 10:50 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 10:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 10:58 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-19-2017, 06:15 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-19-2017, 02:09 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 06:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 07:38 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 08:18 AM
RE: 46-1226 code 125 restoratioin *DONE - by sam - 05-22-2017, 10:45 PM
Antenna options - by jcassity - 05-19-2017, 07:04 AM
Users browsing this thread: 72 Guest(s)
Ooh, very nice!jrblasde — 12:19 PM
I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye. It has 13 tu...Dan Walker — 12:07 PM
Hi guys! I’m a new member here but have been using your resources for quite some time. Hopefully I can get some help wit...Radios1340 — 11:52 AM
There are currently 9458 online users. [Complete List]
» 2 Member(s) | 9456 Guest(s)
