46-1226 code 125 restoratioin *DONE
Threads: 14
City: Irvington, NY
Yes, that is correct. The center tap and C101 negative should only connect to chassis through R100.
Thats why I said to measure the resistance from the center tap to ground. You should read 271 ohms, the resistance of R100.
If you do not read 271 ohms there is a problem. There must be 15 to 20 volts at the center tap to provide bias for the output tubes. This voltage is developed across R100 so if you have no voltage across R100, then the center tap is somehow bypassing R100 with some other path to ground.
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 09:27 AM
Users browsing this thread: 77 Guest(s)
Part 4 of this series now uploaded
link below to anyone interested
Buzz — 02:39 PM |
Welcome to the Phorum, Radios1340! The oscillator coil on the 60 is a common culprit. I just bought a 60B (June 1934) ...GarySP — 02:33 PM |
Yes, standard alignment procedure. I can get the minuscule tone to vary when adjusting the trimmers. But you almost have...Radios1340 — 01:40 PM |
An imposing-looking radio, for sure.morzh — 12:43 PM |
Model 60 struck again :lol:
Welcome to the Phorum!
Above is the article on Model 60. Could be of some use.
Now...morzh — 12:38 PM |
Ooh, very nice!jrblasde — 12:19 PM |
I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye.
It has 13 tu...Dan Walker — 12:07 PM |
Hi guys! I’m a new member here but have been using your resources for quite some time. Hopefully I can get some help wit...Radios1340 — 11:52 AM |
Milkjug plastic?morzh — 09:36 PM |
Yep.
'Cause when I heard "buibble" I immediately thought of this
and started wondering how this poly...morzh — 09:33 PM |
There are currently 9472 online users. [Complete List] » 3 Member(s) | 9469 Guest(s)
