  • 2 Vote(s) - 4.5 Average
Emerson 250AW restore
That's an excellent question Jeff....
I did not even consider that the line cord was resistive but figured that the wire wound resistor (175 ohms) was adjusting the voltage for the input power. I saw on the schematic that the input could be 100 to 135 volts AC or DC with 110 being optimal.
So to answer your question...I did not do anything. Seems to work OK but I have never played it for long periods.
So...help me out guys...is this set supposed to have a resistive cord on it?
There is a "how to" on Nostalgiaair for replacing resistive cords.
Emerson 250AW restore - by klondike98 - 03-27-2017, 12:05 AM
RE: Emerson 250AW restore - by morzh - 03-27-2017, 08:21 AM
RE: Emerson 250AW restore - by OldRestorer - 03-28-2017, 05:04 AM
RE: Emerson 250AW restore - by PhilcoPhan1936 - 05-02-2017, 12:03 PM
RE: Emerson 250AW restore - by klondike98 - 05-02-2017, 12:48 PM
RE: Emerson 250AW restore - by PhilcoPhan1936 - 05-02-2017, 01:12 PM
RE: Emerson 250AW restore - by klondike98 - 05-02-2017, 01:22 PM
RE: Emerson 250AW restore - by Mondial - 05-02-2017, 02:13 PM
RE: Emerson 250AW restore - by klondike98 - 05-02-2017, 02:23 PM
RE: Emerson 250AW restore - by PhilcoPhan1936 - 05-02-2017, 02:25 PM
RE: Emerson 250AW restore - by Mondial - 05-02-2017, 02:32 PM
RE: Emerson 250AW restore - by klondike98 - 05-02-2017, 02:35 PM
RE: Emerson 250AW restore - by klondike98 - 05-02-2017, 02:37 PM
RE: Emerson 250AW restore - by mcusi - 07-08-2017, 07:34 PM
RE: Emerson 250AW restore - by klondike98 - 07-08-2017, 08:02 PM
RE: Emerson 250AW restore - by Radioroslyn - 07-08-2017, 09:16 PM
RE: Emerson 250AW restore - by mcusi - 07-10-2017, 06:19 AM
RE: Emerson 250AW restore - by klondike98 - 08-19-2017, 11:49 AM
RE: Emerson 250AW restore - by Radioroslyn - 08-19-2017, 12:09 PM
RE: Emerson 250AW restore - by Eliot Ness - 08-19-2017, 11:01 PM
RE: Emerson 250AW restore - by OldRestorer - 08-20-2017, 07:28 AM
RE: Emerson 250AW restore - by klondike98 - 08-20-2017, 11:50 AM
RE: Emerson 250AW restore - by klondike98 - 08-22-2017, 07:59 PM
RE: Emerson 250AW restore - by Eliot Ness - 08-23-2017, 08:47 AM
RE: Emerson 250AW restore - by OldRestorer - 08-23-2017, 09:38 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7183 online users. [Complete List]
» 1 Member(s) | 7182 Guest(s)
